Optional Equipment
Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1
The Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1 trim the fore edge and top/bottom of saddle stitched copies for neat output.
Saddle Finisher-AN2
The Saddle Finisher-AN2 is equipped with the following features: Collate, Group, Staple (Corner, Double, and Saddle Stitch), and Saddle Fold.
Staple-P1
The Staple-P1 can be attached to the Saddle Finisher-AN2 for saddle stitching.
4.
Paper Folding Unit-J1
If the Paper Folding Unit-J1 is attached to the Finisher-AN1 or Saddle Finisher-AN2, the paper can be folded in 5 different ways (Z-Fold, Half Fold, C-Fold, Accordion Z-Fold, and Double Parallel Fold).
5.
High Capacity Stacker-H1
The High Capacity Stacker-H1 enables you to continuously stack a large amount of paper. Up to two stackers can be attached to the machine.
6.
Perfect Binder-E1
The Perfect Binder-E1 is equipped with the following features: book binding, gluing, trimming, and stacking.
7.
Multi Function Professional Puncher-A1
The Multi Function Professional Puncher-A1 punches several types of hole. The paper can be creased to be saddle folded easily by changing the die. For more information on the Multi Function Professional Puncher-A1, see the instruction manual of the Multi Function Professional Puncher-A1.
8.
Document Insertion Unit-N1
If the Document Insertion Unit-N1 is attached, a different type of paper from the body of the document can be inserted for a cover or insert.
9.
Duplex Color Image Reader Unit-K1
Originals placed in the feeder are automatically fed sheet by sheet to the platen glass for scanning. You can scan documents such as books, thick originals, thin originals, and transparencies on the platen glass of the Duplex Color Image Reader Unit-K1.
10.
Upright Control Panel-F1
The Upright Control Panel-F1 includes the keys, touch panel display, and indicators required for operating the machine. (See "Control Panel (Upright Control Panel-F1) Parts and Functions.")
11.
POD Deck-D1
If the POD Deck-D1 is attached, it can provide three additional paper sources. Up to 1,000 sheets of paper (20 lb bond (80 g/m2)) each can be loaded into the upper and middle decks, and up to 2,000 sheets of paper (20 lb bond (80 g/m2)) can be loaded into the lower deck of the POD Deck-D1.
12.
Secondary POD Deck-D1
If the Secondary POD Deck-D1 is attached to thePOD Deck-D1 , it can provide three additional paper sources. (A total of six paper sources ) The Secondary POD Deck-D1 holds up to 1,000 sheets of paper (20 lb bond (80 g/m2)) each can be loaded into the upper and middle decks, and up to 2,000 sheets of paper (20 lb bond (80 g/m2)) can be loaded into the lower deck of the Secondary POD Deck-D1.
13.
LONG SHEET TRAY-A1
Use the LONG SHEET TRAY-A1 to feed paper manually.
14.
POD Deck Lite-C1
If the POD Deck Lite-C1 is attached, it can provide an additional paper source. The POD Deck Lite-C1 holds up to 3,500 sheets of paper (20 lb bond (80 g/m2)).
15.
Tab Feeding Attachment-E1
Attach the Tab Feeding Attachment-E1 to load tab paper into the paper decks of this machine.
16.
Finisher-AN1
The Finisher-AN1 is equipped with the following features: Collate, Group, and Staple (Corner and Double).
17.
Staple-N1
The Staple-N1 can be attached to the Finisher-AN1 or Saddle Finisher-AN2 for stapling (Corner and Double).
18.
Puncher Unit-BT1/Puncher Unit-BS1
The Puncher Unit-BT1/Puncher Unit-BS1 is equipped with the Hole Punch mode. The Puncher Unit-BT1/Puncher Unit-BS1 can be attached only if the Finisher-AN1 or Saddle Finisher-AN2 is attached.
19.
Booklet Trimmer-D1
The Booklet Trimmer-D1 trims the fore edge of saddle stitched copies for neat output.
» Optional Products » System Configuration » Optional Equipment
0S9Y-03A
